Trying to recognize PXI-5922 digitizer
I have only been using LabVIEW for about a day now, so everything is more or less still new to me.  I've worked through most of the getting started guide to become aquainted with the program.  Right now I am trying to get it to recognize a NI-DAQmx device.  This device has been used before (but not by me), so I am pretty sure everything should be installed correctly.  One thing I noticed is that when I turn the chassis on, the LEDs on the digitizer do not turn on with it.  I came across this when trying to find possible solutions, http://www.ni.com/pdf/manuals/371133m.pdf  In the trouble shooting guide, there is a section for this exact problem.  It points me to Measurement and Automation explorer to try and reset and self test the device.  The problem is, once I reach it I am greeted with this Measurement and Automation
Maybe I am just overlooking a step since I have only been using this program and equipment for about a day, but could someone put in some input.  Thanks.
(3,258 Views)
The problem still persists.
(3,230 Views)
I'm not sure what you are trying to do. You have said that you are using LabVIEW but apart from that, I have no idea what you are doing. The device looks to be okay in MAX though it would be nice to see the software section and what version of NI-Scope that you have installed.
If the driver is installed, you can go to Start>Programs>National Instruments>NI_SCOPE>SCOPE Front Panel. In LabVIEW and from the block diagram, you have the Instrument I/O>NI-SCOPE palette with the NI-SCOPE Express function.
(3,226 Views)
Accepted by topic author JaRay
I actually got it working on my end since my last reply.  Thanks though.
(3,220 Views)
