Loop is not working
Just started to learn LABVIEW and face this kind of difficulties. The while loop is not working, but when the stop button is pressed the loop is happen only for a cycle. Looking for help/suggestion.
(1,461 Views)
Accepted by MDewey
Move all indicators inside the loop. Think in dataflow. The data in the wires outside the loop only updates once the loop has finished.
(1,445 Views)
Accepted by MDewey
  • Hi Dewey,
The while loop iterates once per second
  • when the Maintainance button is FALSE initially
  • as long as the Stop button is FALSE
You can even see the iteration once you start debugging using the highlight execution tool: you really should use this to help you understand your own code! 🙂
(1,437 Views)
Accepted by MDewey
I'd say the code works as expected, not just as you wanted it to. 🙂
As a tips you can r-click the needle meters and activate Visible Items -> Digital display so you don't need to update 2 controls for each value.
LV will read the Stop button long before it starts the wait, so it'll loop around one extra time and have on average a 1.5 sec stop time.
Qestit Systems
Certified-LabVIEW-Developer
(1,388 Views)
Hi, thank you for your reply. Yes, since the numeric indicator did not showing any number, i thought the problem is on the loop. Thank you for letting me know.
(1,290 Views)
