Lost ActiveX connection with LabVIEW server
I have called LabVIEW in TestStand and tried to execute the test cases .
While executing I got the following error:  ( Lost ActiveX connection with LabVIEW server.
The LabVIEW adapter will try to reconnect on the next execution attempt.-18001; An error occurred accessing the LabVIEW ActiveX automation server.).
(3,984 Views)
i got the same error!
(3,958 Views)
how do you solve this issue?
(3,957 Views)
Same error.  Is anyone from NI going to bother commenting on this?  It's been >8 months...
(3,890 Views)
