Low-Cost Digtial I/O Card compatible with Labview (ISA or PCI, 3.3v or 5v)
I only need 16 i/os or less, but its seems all the cards I've found
either dont mention they are directly supported
within Labview, or they have too many I/Os and are too pricey (i.e.
National Instruments brand)!)
Anyone know where I can get a cheap I/O card, preferably with
selectable 3.3V or 5V operation.
Thanks!
(4,897 Views)
What do you consider cheap?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,884 Views)
How about $89 for the PCI-DIO24 from Measurement Computing including LV drivers...
Mike...
LabVIEW Champion
(4,883 Views)
  I think that the cheapest way is to develop a specail hardware to extend I/O port using PC usb or parallel port.
Good luck,
EVAN
(4,879 Views)
Hello Anonymous,
If your are looking at DI/O device with 16 channels for TTL signals, consider the following for your application:
USB-6501 24-ch 8.5mA
PCI-6503
These instruments as fully compatible with LabVIEW. If you need more information on these devices or other hardware solutions feel free to contact us. We will be glad to assist you.
  Sandra T.
Applications Engineer | National Instruments
(4,864 Views)
If I'm not mistaken, the PCI-DIO24 is not compatible with winXP.   Which, if thats the case, I'm guessing that Labview doesnt support it either.
Can someone verify this?
>Mike...
(4,805 Views)
Hi All-
Sandra's suggestion of the USB-6501 is probably your best bet.  It is fully supported by NI-DAQmx (the device driver, included with the purchase of the device) and LabVIEW (currently versions 8.2.x, 8.0.x, and 7.1.x) under Windows 2000/XP/Vista.  It's inexpensive and supports 3.3V/5V selectable operation.  It is the lowest cost option from NI (other than the USB-6009, which does not meet your I/O count needs) that supports configurable digital logic levels.
Message Edited by Tom W [DE] on 06-28-2007 05:31 PM
Tom W
(4,793 Views)
