Lwbview execs on MySQL
I compiled some 32bit execs on a 64 bit Windows computer, that read and write to MySQL. The vis are running fine on that machine.
Now I installed MySQL on another, Windows 7 64 bit, and I get some errors,
Error -2147287037 and ADO Error: 0x80030003.
MySQL server is running, passwords are ok, table exists with matching columns.
Seems there are problems with the 32/64 bit ODBC socket. Whats the best option, 64 bit MySQL server or 32 bit?
Thanks!
(3,633 Views)
Accepted by Steffen01
Use the ODBC administrator in the C:\Windows\SysWOW64\odbcad32.exe directory.
aputman
(3,584 Views)
I did, when I run it from the syswow64 folder its happy, but when I ron ODBC from the windows prompt, its not. As in, throws up an error.
But the good news is, its working now. I used a subvi that had a fileprompt. So it could not find the udl file, once compiled to an .exe. I realised that, when I run the .exe on the Labview computer, it did not connect either. So I changed that subvi part to just a file imput sting that I could change manually and now it works.
I prefer to use Labview 32 bit, since it has more optinins than 64 bit.
https://www.ni.com/en/support/documentation/compatibility/09/national-instruments-product-compatibil...
(3,572 Views)
for the future reader, reinstalling visual C++ redist, now at least I can ODBC admin from the SYSwow64 folder.
or I check this one, can change it in the registry
https://superuser.com/questions/419832/how-can-i-open-the-32-bit-odbc-data-source-administrator-in-w...
depends, how commited users are.
(3,562 Views)
