MASTER/SLAVE PATTERN: how to stop slave loop without stop main loop
Don't use a timeout on your dequeue. Only execute when you actually have something to work on.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 16
(1,040 Views)
The case structure connected with Dequeue has no "time out", could you tell me where can I change to solve the problem in the vi file I uploaded? Thank you very much!
Message 12 of 16
(1,037 Views)
See below where you are setting the dequeue timeout.
Mark Yedinak
LabVIEW Champion
Message 13 of 16
(1,034 Views)
Hi Mark_Yedinak, I followed your advise and make this vi work. Thank you very much! But I got another problem. As you know, the uploaded program is a simplified one, and the real program has very complicated main loop. Now in my program, when I click the boolean buttin in the main loop (like "start/stop 3" button in my uploaded program), it cannot change the status and is kept in "False" state. Could you advise what is the possible cause for this kind of situation? Thank you very much!
Message 14 of 16
(1,021 Views)
Without seeing the code I couldn't really give you any advise.
Mark Yedinak
LabVIEW Champion
Message 15 of 16
(1,013 Views)
 i would send a notifier to your sub vi....
Spoiler
Message 16 of 16
(1,003 Views)
