MATLAB reducem function
Is there a way to use the MATLAB reducem function from LabVIEW? I don't see any documentation about it. Maybe it's a data type issue?
David A. Moore, Ph.D.
President
Moore Good Ideas, Inc.
(3,237 Views)
Hi David,
what have you tried so far? Where are you stuck?
That being said: MathScript <> MATLAB.
Have you tried the Matlab script node?
(3,195 Views)
I don't have a MATLAB license, so no. I just found the reducem function when looking for how to simplify contours, and there's one other spot in this application where I use a MathScript function to do something.
President
(3,190 Views)
Hi David,
MathScript is similar to Matlab syntax, but supports only a limited subset of the whole Matlab command set.
I guess you know that…
(3,183 Views)
It looks like a better strategy will be using a stand alone library for this functionality. I'm going to see if I can get this to work:
https://github.com/imshz/simplify-net
President
(3,179 Views)
Don't forget that newer LabVIEW versions also have a python node and there is a python port of this too. (there are also others that do about the same.)
(3,171 Views)
Sadly, I don't even remember what I was trying to do with it five years ago.
President
(567 Views)
