MAX Can't Call VISA
Hey Guys,
Im fairly new to LabVIEW, but im really troubling right now with NI MAX,
Im trying to add a new VISA TCP ressource ( raw socket to be percise), but NI MAX does not show this as an option.
NI Max 20.0 and NI VISA 20.0 (+ runtime 20.0) are installed. Do i need to connect those together manually?
(795 Views)
Accepted by mellio
I would like to suggest to reinstall VISA and select everything, all available features.
Not sure, but I think this option is important at least:
Technically you don't need to install exactly 20, the 2023Q4 is also compatible with LabVIEW 2020:
Not sure about latest 2024Q1, NI hasn't updated yet compatibility chart.
(779 Views)
 Often you have to add it manually though NI-MAX.  Have you tried that yet?
Bill
CLD
(Mid-Level minion.)
(738 Views)
