[MAX/DSC] Unable to archive Citadel data by time interval
I've run into an issue on 2 separate PCs. How do I archive a subset of Citadel data?
Setup
  • Win7 x86 and Win7 x64
  • LabVIEW 2013 SP1 f2 (with DSC module)
  • NI MAX 5.6.0f0
Steps to reproduce
From NI MAX…
  1. Create a new database called "MainDB" in C:\MainDB
From the DSM…
  1. Add a new process called "TestProcess". Enable data logging into MainDB.
  2. Add a new variable called "Var1" in TestProcess. Enable logging without alarms/events.
  3. Update the value of Var1 multiple times to log 60 seconds' worth of data (my test was from 10:24:30 AM to 10:25:30 AM)
  4. Stop TestProcess
From NI MAX again…
  1. Open My System -> Historical Data -> Citadel 5 Universe, and select Universe -> My Computer -> MainDB -> PC121 -> TestProcess -> Var1
  2. Click "View Data" to verify that the trace is there.
  3. Create a new database called "BackupDB" in C:\BackupDB.
  4. Right-click MainDB -> PC121 -> TestProcess -> Var1, and select "Archive…"
  5. Select BackupDB as the Destination Database
  6. Enter a time interval. I tried a few different ones:
    1. From "No Start Time" to 10:25:10 AM
    2. From 10:25:00 AM to 10:25:10 AM
    3. From 10:25:00 AM to "No End Time
  7. Check "Destroy source data after it has been archived"
  8. Click "Finish"
Expected behaviour
  • Only the data within the specified time interval should be copied from MainDB to BackupDB
  • Only the data within the specified time interval should be deleted from MainDB
Observed behaviour
  • Everything is copied from MainDB to BackupDB
  • Nothing was deleted from MainDB, even though the dialog says "Destroyed data from "\\PC121\MainDB\PC121\TestProcess\Variable" within specified time interval"
Other notes
  • I tried unchecking "Destroy source data after it has been archived", but still the whole database got copied
  • I also tried the Archive Traces VI but got the same results
Certified LabVIEW Developer
(3,438 Views)
I was able to reproduce this - currently looking into it.
David H.
(3,399 Views)
I want to try doing this with LabVIEW using a programmatic approach instead of just through MAX and DSM. It make take me awhile - you may want to try the same thing on your end. I'm particularly wondering whether this is something recent and if it had worked fine in the past.
David H.
(3,364 Views)
Still looking into this at the moment - We will most likely have an update next week.
David H.
(3,306 Views)
Accepted by JKSH
This does seem like a reproducible bug - I'm going to go ahead and put in a corrective action request to R&D.
David H.
(3,232 Views)
Thank you very much for your time, David!
Could you please post the CAR number?
(3,223 Views)
Absolutely - It's CAR #481053.
David H.
(3,205 Views)
