MAX does not see the devices and interfaces
  Just got a laptop to support the lab and installed Labview. For reasons I do not understands MAX does not see the com and USB ports in the laptop. The IT department gacve my id admin rights. Any ideas what is going on?
Kaspar
Kaspar
(2,867 Views)
Did you open up MAX and verify that NI-VISA is installed? If it is, what version and what OS are you using?
(2,853 Views)
Accepted by topic author Kaspar
Dennis, as usual, is correct.  Please check to see if NI-VISA is installed.  There's a KnowledgeBase article on how the com ports will not appear in MAX unless NI-VISA is installed.  The link for this article is below.
http://digital.ni.com/public.nsf/allkb/1FAB687036A2D85B862571490072307A?OpenDocument
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
(2,806 Views)
Hello, That was it, when I installed NI VISA I was able to see the the hardware interfaces. Thanks again!
Regards, Kaspar
Kaspar
(2,800 Views)
