MAX test panels
Is there a way to load a full function version of NI MAX (must have test panels) without LabVIEW? Or what is the minimum LabVIEW components necessary to have NI MAX with test panels.
Message 1 of 14
(4,398 Views)
NI max installs under the System Configuration tool, which installs with LabVIEW by default but can be installed by itself.
I believe that test panels come with NI-DAQmx for DAQ devices and for direct communications with NI-VISA, but I'm not totally sure as I nearly always install LabVIEW first.
Maybe tell us what you're trying to do in the first place and then circle back to the "How?" part afterwards?
Message 2 of 14
(4,389 Views)
You do realize that a Test Panel is linked to a device, so MAX with no LabVIEW drivers doesn't make much sense (to me).  Indeed, the idea of MAX without LabVIEW I find very curious.
Bob Schor
Message 3 of 14
(4,369 Views)
You need to also keep in mind that not all devices have a test panel in NI Max. You should have test panels for any device that has one for NI Max if you install the device drivers without LabVIEW.
Tim
GHSP
Message 4 of 14
(4,353 Views)
I've written an application that controls a unique piece of hardware through a PCI card on a PC.  I've made the application into an executable complete with installer so it can be installed on any computer.  I have 5 of copies of this setup to build.  I'd like to test the each setup, however, the installer only supplies a minimal version of LabVIEW for the executable to run. I need MAX to test the PCI card and thus the hardware.
Message 5 of 14
(4,335 Views)
Is there a reason why you can't include MAX in your installer?
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 6 of 14
(4,306 Views)
The Installer automatically adds LabVIEW Runtime and DAQmx Runtime. Are you thinking NI System Configuration Runtime?  If so, there are lots of other dependencies.
Message 7 of 14
(4,271 Views)
Does this help?
Manually Include NI MAX in a LabVIEW-Built Installer
Message 8 of 14
(4,264 Views)
I don't see that option in LabVIEW 2016
Message 9 of 14
(4,257 Views)
The image below is from a LabVIEW 2016 project. Note that 2018 device drivers are used
because LV 17 and 18 are also on this PC.
I suggest reinstalling Device Drivers.
Message 10 of 14
(4,252 Views)
