MAX with sound input
How can I use MAX (the Measurement and Automation program) to test if the computer is able to read voltage changes via the sound card (fed into the computer via the microphone jack). Please walk me through the process...
Thank you!
(3,106 Views)
MAX is for NI cards only.  Is your sound card an NI card; I don't think they make one?
Message Edited by nyc on 07-13-2006 10:19 AM
(3,102 Views)
Then how do I read the voltage input (via the microphone jack) in LabView?? (What functions should I use and in what order?)
Thank you.
(3,095 Views)
Open the example finder and look under Hardware Input and Output>Sound. The sound functions can be found on the Graphics & Sound>Sound palette.
(3,084 Views)
