MCP960X/ microchip Programming
I am trying to program this in LABView, but I am relatively new. I have attached the data sheet, but just need some advice. How exactly do I write the data to a specific 'bit address',? should I use the VISA function instead? Do you have any tips about programming microchips in labview? anything will help, I appreciate the time.
(4,088 Views)
Accepted by arosss
Hi arosss,
you need some hardware capable of I²C communication.
NI offers some modules for that communication bus, but you can also use cheap devices like Arduino for that purpose…
Which hardware do you want to use?
(4,086 Views)
I have downloaded a couple I2C modules. But arduino's are also an option. I have downloaded this one off VI Package manager. I was just hoping for any tips that you may be able to provide. I am trying to get the hang of this.
Again thank you!
(4,066 Views)
Hi arosss,
how can you download hardware?
About your attached image: why don't you ask the author?
To "get the hang" you should take note of the training resources offered in the header of the LabVIEW board.
(4,052 Views)
I am using NI myRIO 1900. Having trouble adding the target without errors.
(4,023 Views)
