MIL-STD-1553 Astronics Ballard LabVIEW
Is there an example program in LabVIEW to configure my Astronics Ballard 1553 Module as a BC.  The BC operate at in a 4Hz loop and sends 1 Message containing 2 words to a RT (10) and requests the RT to return 1 message containing 19 words back to the BC?  Thanks for your time and help.
(4,203 Views)
Did you check the manual/drivers link on the product page?  I did not want to create an account to check.
Towards the bottom of the page it says:
Software
  • Universal BTIDriver API for C/C++, C#, VB, VB.Net, and LabVIEWTM
So I would imagine you could find something documented in the link.  If not, contact customer support and ask them.  Or someone else here will be able to help you out.
(4,173 Views)
Hi, were you able to find a solution? I also need an example program for the exact scenario.
(3,792 Views)
Sorry, I don't have access to LabVIEW anymore as I delivered the hardware/software to my customer.  I recall creating the xml file to create the messages and data rate of 4Hz for those messages.  Then, I used the Ballard BC functions to send and receive those messages.
(3,777 Views)
Ok, Thank you.
(3,764 Views)
