MODBUS RTU SERIAL
I would like to know the basics for the Modbus rtu serial server in DSC the document in the labview is given for periodic server
If some changes are to be made plz specify
Regards
Pallav
Message 1 of 8
(5,006 Views)
Regards
Pallav
What kind of changes would you like to make?
Please provide a zip of your project and clearly specify your end goal.
Just trying to help,
Ben
Message 2 of 8
(5,001 Views)
I have a device (RTU) which gives modbus register output and i want to read it at the PC end Plz guide for the above for procedure to be followed. Thanks for replying
Message 3 of 8
(4,966 Views)
you may not need the entire dsc module. How much info do you want to read and how fast?? Try the NI modbus library.
http://sine.ni.com/devzone/cda/epd/p/id/4756
Lots of examples for this code in the forums.
Message 4 of 8
(4,953 Views)
Thanks for replying
I need to read more register at higher data speed so if i m not wrong i'll have to use the DSC module,
If i'm wrong plz correct me
Can i have the link for basics for DSC module (MODBUS)
Thanks for taking interest.
Regards
Message 5 of 8
(4,928 Views)
How many is more? 100, 500, 1000?? 10ms, 50ms, 100ms scan rate??
Message 6 of 8
(4,917 Views)
Sorry for Delay
Its 200 for 50 ms Is it done by modbus lib or dsc is needed?
Regards
Message 7 of 8
(4,875 Views)
if they are all consecutive registers, you could do this with two modbus read commands in blocks of 100 registers. This could probably be done with just the NI modbus library. Use RTU mode and set the baud rate to 19200 or higher.
Message 8 of 8
(4,866 Views)
