what are object and port handles in CAN communication via labview
I have just started working on the NI labview...i had a problem that when i changed the bitrate using CAN interface create-->CAN SDO create-->CAN write.after that i am not able to communicate with the device with the new bitrate....i have seen a few similiar forums, which talks about object and port handles as an solution of the problems..
As
forums.ni.com/ni/board/message?board.id=30&thread.id=3405......
So i want ask that is this object and port handles....
Message 1 of 1
(2,470 Views)
