MOVE CONTENTS OF BLOCK DIAGRAM TO FRONT PANEL
New to labview,
created block diagram how do i move it to front panel
(3,293 Views)
I think you are not understanding the concept. Think of an electrical control panel, with meters and knobs and switches on the front panel. Behind that front panel are the wires and other circuitry that is controlled by and feeds those switches and meters. This is what the front panel, diagram relationship in LabVIEW is similar to. If you have some LabVIEW code tell us what it is supposed to do, and ideally, post the code to this forum.
Putnam
Certified LabVIEW Developer
LabVIEW Champion
(3,288 Views)
Accepted by DMG1
Maybe you should check out these tutorials:
LabVIEW Basics
LabVIEW 101
(3,280 Views)
So true do not understand at all, company bought and gave one day to learn and no training
(3,278 Views)
thanks some place to start
(3,273 Views)
I know that feeling all too well.  Check out the tutorials I linked to above.  They should at least get you started.  If you run into problems, don't be afraid to ask us.  We're here to share ideas and help people learn.  And please give Kudos to helpful posts.
(3,271 Views)
As the previous post says, don't be afraid to come back for assistance. This forum ranges from those just starting to some of the world's experts in LabVIEW.
Putnam
LabVIEW Champion
(3,226 Views)
