MOXA Ethernet to RS232 For Arduino
Hello
I am working on something a little bit specific... I hope you could help !
I am using Labview --> Moxa Ethernet to RS232 -->MAX323 (to TTL 5V)--> Arduino UNO
What I would like to do first is a simple application : control the led ON/OFF (pin 13) via Labview.
As I use the MOXA, I guess I need to use VISA because the Arduino is not seen as a COM port anymore... But I can't find a way to send something via pin 0/1.
Could you help me ? Is that possible to do ?
Thank you !
(3,215 Views)
When I run my VI, I can see the TX light on the MOXA ON, so I think my issue is more on the arduino side...
(3,159 Views)
