MS ACCESS OK -- SAME VI NO WORK FOR ORACLE?? USING LV8.6 AND DB TOOLKIT
What is Get Task Information.vi used for? I usually use Execute query -> Fetch all(/attribute) -> Close Query
I also had the issue of not getting any attribute for the number of rows recieved, which i solved by by doing a Select count(*) query instead. Not optimal since it's an extra query, but general enough to work against both my access and sql server and through odbc. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 13
(598 Views)
Yamaeda,
This post is specificly about fixxing Error -2147217887. If you have other questions about database functions start a new thread.
Message 12 of 13
(584 Views)
I have moved on from this problem and am just using the Advanced Tools and SQL, INSERT CMD -- mostly to enter the Test DATA, which we parse out of the Test results. For what I need to do, this works fine. I am working the Oracle people @ our company to develop the specific Table info and Database design so the data can be easily accessed with their designed forms etc, and be applied to other product etc.
Message 13 of 13
(577 Views)
