MSP430F5528 Read Data
@Dave3345554 wrote:
Then I would need to go through CCS in order to send data to LabVIEW? Or I can't send any data out of that application at all?
You are not paying attention.
You don't need anything except a terminal application such as Teraterm or RealTerm or Putty to debug the communication.
Message 11 of 14
(1,009 Views)
Are you able to point me in the right direction for using a terminal application to debug the communication and connect to LabVIEW? I am not sure where to begin, so advice would be appreciated.
Message 12 of 14
(1,000 Views)
I give up.
If I didn't know any better, I'd think you were trolling here.
Message 13 of 14
(994 Views)
Those sorts of errors often pop up when the resource you are trying to access is being used by another program. When VISA Interactive Control is trying to communicate, are any other programs also interfacing with the device? You can try to ensure this by rebooting the computer, ensuring VISAIC is the only program communicating with the device.
Kevin S.
Technical Support Engineering
Message 14 of 14
(973 Views)
