MY TDMS FileViewer PanelResize Problem.....
Hi Labview World,
I created my tdms fileviewer.My tdms fileviewer is likely to deafult tdms file viewer.
My problem is that my tdms file viewer panel resize functon doesnt work correctly.actually i know what is the problem some vi is locked from NI Engi so i didnt modified.
I want to use wave form chart, default tdms used graph.I found unlocked panelresize ( http://forums.ni.com/ni/board/message?board.id=170&message.id=424445&query.id=7425932#M424445)
i tried this (doesnt work). I am not sure but this vi includes another subvi (getplotbounds.vi).This vi is locked.
Shortly, how can work panelresize function with waveform chart I send my all tdms fileviewer to solve this problem.Thank u...
(3,900 Views)
(3,863 Views)
Somebody can solve this problem:)))) help meeee:)))
(3,860 Views)
I went to ni.com and typed the following words into the search field on the first page:
tdms file viewer resize
The first result in the list has the solution.
Hope that helps,
Herbert
(3,849 Views)
Hope that helps,
Herbert
fisrtly thank u for helping Herbert,
I tried this solution if u have a time you can see my code and u tell me what is the wrong step for my tdms....every thing is ok but panel resize is a nightmare:)))
(3,830 Views)
ı solved this problem thank u for every things...
(3,807 Views)
