Input sensitivity
Does the SCXI-1100 sense analog inputs that are as low as 10mV?
(2,825 Views)
SCXI-1100 Users Manual -> https://www.ni.com/docs/en-US/bundle/320637c/resource/320637c.pdf
There it says: "This module is designed for low-cost signal conditioning of thermocouples, volt sources, millivolt sources, and 4 to 20 mA sources or 0 to 20 mA process-current sources."
Btw, this would fit better in the hardware forums
Christian
(2,803 Views)
