Mac DAQmxBase 15.0 Drivers not working for LabVIEW 2016
On loading my .vi i keep getting that the DAQmxBase drivers could not be loaded although they are installed
-http://forums.ni.com/t5/NI-DAQmx-Base-Developers/NI-DAQmx-Base-for-LabVIEW-2016-on-Mac-OS-X/gpm-p/35...
i've tried this with no succes.Please advice 🙂 .
(3,281 Views)
In another context, within the last six months I needed to get DAQmx drivers for another version of LabVIEW and followed a similar suggestion for converting NI-DAQmx drivers.  It also didn't work, so I gave up and decided to "wait patiently".
If you have working DAQmx Drivers for LabVIEW 2015 on the MAC, I'd suggest running LabVIEW 2015.  On the other hand, LabVIEW 2017 should be released in about a month, so maybe the MAC drivers for DAQmx that come with LabVIEW 2017 (assuming they are there) will work with LabVIEW 2016 ...
(3,233 Views)
The problem is my LabVIEW program doesn't want to open in 2015 because it's made in 2016.
(3,224 Views)
Then open it in LabVIEW 2016 and use the Save for Previous Version from the File menu.
(3,216 Views)
