Mach3 ActiveX
Hello Experts,
I am in trouble with an ActiveX Call.  Given an application called: Mach3 a CNC program. Link: http://www.machsupport.com/downloads.php     Mach3 R3.043.066
I would like to interface it with LabVIEW via ActiveX. I found a similar topic in NI forum but the questioner uses LabWindows/CVI. Link: http://forums.ni.com/t5/LabWindows-CVI/ActiveX-controller-methods-import-as-callbacks/td-p/1038846
After installing the Mach3 on WindowsXP 32Bit, I found the tlb file that can be used for ActiveX calls under the following path: C:\Mach3\Mach4.tlb.
When I check : "Show Creatable Object Only" I can not see the complete list of ActiveX calls and function returns an error:
Class is not registered.
I've registered the Mach4.tlb file with regtlb.exe under Windows\.NET\Framework without any success.
Selecting IMyScriptObject to open, the ActiveX calls appeared but I always got an error message: Object specified is not creatable in ...
Could you give me some help how to go on? Looking forward you kind reply!
+++ In God we believe, in Trance we Trust +++
[Hungary]
(9,415 Views)
Accepted by D60
Hi!
I've downloaded the current versin of Mach3. What worked for me was:
1. Restarting computer after installing Mach3.
1. Make sure Mach3 is running in the background, without that, class objects we not available.
2. Create an Automation Open, with a constant as the input.
4. Browse for object class, select:
5. There's a handful of methods available for that particular class. This code checks the revision nr.:
This is what I was capable of reaching via LV ActiveX.
Hope this helps.
Regards:
Andrew Valko
NI Hungary
Andrew Valko
National Instruments Hungary
(9,383 Views)
Thank you so much for your help. I have tried something similar to your code, but Mach3 was not running. You are great!
[Hungary]
(9,374 Views)
HI, I am also working on the same thing.
But I need to use the functions which are in  the non-creatable classes IMyscriptobject.
from the this earlier post  on Lbawindows CVI , http://forums.ni.com/t5/LabWindows-CVI/ActiveX-controller-methods-import-as-callbacks/td-p/1038846
I  understand that we need the following steps(correct me if am wrong)
// get Imach4(which we do when we invoke node after giving the refunm and autmation open)
   Mach4_ActiveIMach4 ("c:\\Mach3\\Mach3.exe", 1, LOCALE_NEUTRAL, 0, &MachHandle);
//get SprictObjectHandle  using GetScript Dispatch ( we have this function in Ithe node IMach4 we created earlier)
    Mach4_IMach4GetScriptDispatch (MachHandle, NULL, &ScriptObjectHandle);
// get the final function needed from scriptobjecthandle.
    Mach4_IMyScriptObjectCode (ScriptObjectHandle, NULL, "G20 x-1 z-1 y-1");
How can we do this is Labview (with just the GUIs)
For example, I want to use DoOemButton(135) . How would I do that.
Thanks in advance.
(8,993 Views)
hello
i also same problem have
Mach3 ActiveX use make Labview VI
i find your Answer
then i try make Same make ,
if run exec Mach3.exe just run......
i just want use dll.. but can't?
Please help your answer
(7,625 Views)
I found additional information that might be helpful here.  On the NewFangled Solutions MachSupport forum I found this post that also explains how to get more useful features out of the ActiveX object in LabVIEW.
It was posted by a user SamZ at https://www.machsupport.com/forum/index.php?topic=23525.msg165202#msg165202
I hope this helps someone else.
(7,398 Views)
한국분들은 아래 영상 참조하세요~
https://youtu.be/3J22mikGUxo
(6,493 Views)
