Magnification in Picture control seems impossible
Hi all, I am trying to magnify/zoom the trace drawn on the picture control. I have had look
at various ways to do this but, when i do apply those methods, my trace drawn is changing
its properties of curvature. It becomes more sharp and the curves disappear. Please help me
solve this problem as i am stuck with this and not able to move ahead in the project thats
close to my heart.
The values to be plotted are stored in a text file attached. The VI must plot the same trace
as can be seen to about 16 times bigger than its present size without changing its
properties of curvature and shape. The data drawn from the text file must be the same but the most important thing is to maintain the properties of the trace 100%
Thanks in advance for the help.
Raj.
(3,452 Views)
Have you tried the property node: zoom factor of picture control?
George Zou
http://www.geocities.com/gzou999
George Zou
(3,438 Views)
i did not find any specific part that speaks about picture control there. can you please elaborate.
also find the attachment to understand better..
(3,418 Views)
See attached zip file.
George Zou
(3,401 Views)
To OP: By the way, instead of using that for loop to build your cluster use the Index & Bundle Cluster Array function. It does the same thing.
(3,381 Views)
