Need help in resolving a Controller-ramp function
i use 2 valves named valve 1 and valve2.      Both outputs vary between 0-100%. i would like to control the output of valve2 with a +ve and -ve ramp.
when i have valve1 with an output less than 20%, i open the valve2 till the valve 1 is closed upto 50% (i use an independent PID for valve 1). and if valve1 opens above 80%, i close valve2  till the valve1 reaches 50%.
i need to use 60 seconds to valve2max and 60 output increments to control valve2.
now i'm trying to work with the +ve ramp.
please give your valuable suggestions and please correct me in making my LabVIEW code better...
Kudos always welcome for helpful posts 🙂
Message 1 of 11
(5,729 Views)
i have problems with using the exact 60 output increments.
Message 2 of 11
(5,729 Views)
hello Renn,
first of all , before coding anything else, dot not use staked sequence any more, it's unscalable
have a look on event structure and state machine, with search function and with labview templates.
ps: i'm looking for links and i'll repost
Best regards
Tinnitus
http://zone.ni.com/devzone/cda/tut/p/id/3024
Message Edité par tinnitus le 02-01-2009 12:12 PM
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 3 of 11
(5,719 Views)
http://zone.ni.com/devzone/cda/tut/p/id/7466
Message 4 of 11
(5,712 Views)
Hello Tinnitus,
thanks so much for your reply.
could you please  send the link again? the url "http://zone.ni.com/devzone/cda/tut/p/id/3024" is not valid
Renn
Message 5 of 11
(5,712 Views)
sorry its appends , i don't know why,
try to make a copy-past in url
tell if it work by this way
Message 6 of 11
(5,707 Views)
there is two links: one ending with 7466 other with 3024
Message Edité par tinnitus le 02-01-2009 12:25 PM
Message 7 of 11
(5,704 Views)
Hi Tinnitus,
as you suggested, i tried a statemaschine version of the same requirements. i feel it more compact.
but still i have a problem with the ramp - i mean the increment of Valve 2 output.
please have a look at the attached  Vi. i am not getting a possible solution to better increment the V2 output
V1max=V2max=100.
time to increment V2 from 0-100 is 60 seconds
thanks
Renn
Message 8 of 11
(5,676 Views)
i think the while loop execution rate is a bit higher to make the remainder output in case "+ve ramp V2" equal to zero
Message 9 of 11
(5,674 Views)
Message Edité par tinnitus le 02-01-2009 02:24 PM
Message 10 of 11
(5,662 Views)
