Mail Merge using ActiveX in MS Word
Labview Gurus:
Anyone of you tried using a popular feature of MS Word � Mail Merge?
Pretty much what I am trying to do is for a word template to read from Excel and load data onto the pre-defined fields. I could do it manually, but when it comes the time calling LabVIEW Activex to perform the same task, it failed.
Any thoughts/Inputs/Recommendations?
USCTrojan
p.s. I know that this Report Generation Toolkit might help, but the funding for the project is tight, so that will not be an option at this time.
(2,860 Views)
After some trial and error, I am now able to answer my own question.
After calling setting up the correct property (Mailmerge.DataSource) and methods (in my case FirstRecord and LastRecord), what threw me off was that I actually had to wire the property to a method called �Execute�, the method that starts the MailMerge. After this method, you can wire the diagram as you normally would (Save and Quit Application), along with close application object.
I hope this helps for anyone who plans to use MailMerge in the future!
USCTrojan
(2,860 Views)
