Make an installer
there u go i put some files in ,llb Hope that will help , you guys need to make .exe file to see my problem.
thank you
Message Edited by kmous on 09-03-2008 05:55 PM
LV 8.2
Message 11 of 29
(1,814 Views)
You forgot some files and a dll.... Your application is huge..
Check out the example I made for you to automatically update a VI path when you turn it into an exe. It may fix the problem.
It's always sunny in California! Certified LabVIEW Associate Developer!
Message 12 of 29
(1,802 Views)
And I hope you realize that you cannot select a pull-down menu (or do anything else) while any of your subVIs are running.
Message 13 of 29
(1,797 Views)
yea I did realize that , so the problem is in my UI.vi ?
LV 8.2
Message 14 of 29
(1,783 Views)
must I include it in my exe ? and run it after ?
LV 8.2
Message 15 of 29
(1,782 Views)
could u save it in LV 8.2 please
LV 8.2
Message 16 of 29
(1,778 Views)
Message 17 of 29
(1,756 Views)
but how this works ? should i include it within my application ?
LV 8.2
Message 18 of 29
(1,746 Views)
The VI that you are using to open the word file, is that something you found, something you wrote, or something that is part of an NI Toolkit? It seems like your problem is with this and I have no idea what is inside it. The Update Path VI is used to adjust the current VIs path to take into account whether or not the VI is running as a built app or in the development environment. If you are using Get Current VIs path in order to opne your word doc, then you should be using the Update Path VI.
Message 19 of 29
(1,741 Views)
Something i found somwhere in the forum , i dont remember , but i guess it is working well.
Could you try just make an installer with my files and see how it freezez up ?
here is a link to my VI's
http://www.megaupload.com/?d=YSHMD33U
Thank you
LV 8.2
Message 20 of 29
(1,690 Views)
