Make main window freeze when I open settings vi
Hello!
I'm apologizing in advance, as the English is not my native language, so I don't know if I will be able to explain clearly what I want.
I have a queued message handler as my main vi, and I want to add Settings vi that pops up when I click on a Settings button in my main vi. I did that, and it's working great, but when settings vi opens I can still click on buttons and set focus to my main vi. I don't want that, as I would like the user to focus on settings window only, and I want main window to be "frozen" while settings is open.
Is there any way to do this?
(3,201 Views)
Accepted by tcvitanic
You basically want your settings VI to be a popup. There is a setting for that.
For the settings VI,
Go to File -> VI Properties -> Window appearance -> Customize -> Window behavior
Changing the window behavior property to modal will resolve your issue.
Best Regards,
Certified LabVIEW Developer
Certified Architect
(3,171 Views)
@tcvitanic wrote:
Hello!
As a compliment: Your English is better than mine, and I grew up with the language!
Bill
CLD
(Mid-Level minion.)
(3,143 Views)
