Make main window freeze when I open settings vi
Hello!
I'm apologizing in advance, as the English is not my native language, so I don't know if I will be able to explain clearly what I want.
I have a queued message handler as my main vi, and I want to add Settings vi that pops up when I click on a Settings button in my main vi. I did that, and it's working great, but when settings vi opens I can still click on buttons and set focus to my main vi. I don't want that, as I would like the user to focus on settings window only, and I want main window to be "frozen" while settings is open.
Is there any way to do this?
(3,193 Views)
Accepted by topic author tcvitanic
You basically want your settings VI to be a popup. There is a setting for that.
For the settings VI,
Go to File -> VI Properties -> Window appearance -> Customize -> Window behavior
Changing the window behavior property to modal will resolve your issue.
Best Regards,
Certified LabVIEW Developer
Certified Architect
(3,163 Views)
@tcvitanic wrote:
Hello!
As a compliment: Your English is better than mine, and I grew up with the language!
Bill
CLD
(Mid-Level minion.)
(3,135 Views)
