Make the picture indicator black on the front panel.
Dear All,
 I’m new to LabView.  I’m working on a project that will display a picture on the front panel. I have a picture indicator on the front panel, the indicator’s background color is white.  I need it to be a black color background.  I looked at the property, etc…  could not find the place that I can get it to work even though it sounds simple.
I thank you in advance for your help!
(2,713 Views)
Use the paintbrush on the tools palette.  (Shift right click)
Paint it a color, then right click to get the color palette and change the color.
(2,701 Views)
Accepted by topic author a2h
Hello Ravens Fan,
Thank you! It solved my problem. I only looked at the indicator itself, I should have checked others.
I appreciate your help. Have a great day.
(2,694 Views)
