how to capture external signal
I built an EMG system. How do i get the signal into simulink so i can apply filtering to it ? I have this built on a breadboard. I know I can use the sound card from the computer. The highest signal I will have is around 2kHz so my sampling rate should be about 6khz. Do i just run a wire from sound card and into my breadboard ? Any help would be great
(2,564 Views)
Yes you can connect your sound card also to grab the signal .. this case study can help you
1) http://digital.ni.com/worldwide/singapore.nsf/web/all/F63DB5F4E101AA128625703D0047111A
2) http://digital.ni.com/public.nsf/allkb/300D8D670193C401862571FE003F3B86
NI provides lots of data acqusition hardware .. you can have a look on link below
http://www.ni.com/dataacquisition/
BR, HS
(2,558 Views)
Hi integralx2,
Can you elaborate a bit more about your application? Are you using any NI hardware or software, such as LabVIEW? If so, can you elaborate on how this is integrated into your application?
Thanks!
Aaron P
http://www.ni.com/support
(2,519 Views)
