Making SubVI terminals REQUIRED
I have a vague memory that several years ago (LV 8, maybe?) there was a LabVIEW option (Tools - Options) to make all new subVI input terminals default to REQUIRED.
IOW, any new VI that had an input terminal created, would have it set to REQUIRED. You could still set it otherwise, but this was the default.
I tried it then, and it worked, but was not suitable for the project I was on.
In looking for it now, I can't find it in LV2013 options.
(  ) I'm missing it - it's right there in the _____ section.
(  ) It's removed and only available by the ______ key in "LabVIEW.ini"
(  ) It's removed and no longer available.
(  ) I imagined the whole thing.
Steve Bird
Culverson.com
LinkedIn
(4,366 Views)
Accepted by CoastalMaineBird
Select Tools»Options»Front Panel and place a checkmark in the Connector pane terminals default to required checkbox.
From: https://zone.ni.com/reference/en-XX/help/371361K-01/lvhowto/specifying_required_recomm/
uday
(4,360 Views)
Well, duh.  < slaps face >
Thanks.
Steve Bird
Culverson.com
LinkedIn
(4,354 Views)
This feature has saved me countless hours of development time by breaking VIs that contain subVIs with modified connector panes so I can easily find them and deal with them.
Bill
CLD
(Mid-Level minion.)
(4,323 Views)
