Making a table of XML information stored in .tdm files Ver.2
Is it possible to make a table compiling all the text information in the .tdm files within a folder and subfolders?"
I have received some helpful information on .tdm format but this question remains unanswered. Basically this would create an index of the folder's .tdm contents.
RL
(2,469 Views)
Yes, it is possible, but there is currently no VI in LabVIEW that helps you with that. You would need a loop that goes over all your folders and lists the files (see attachment or DevZone). Then, for each result file, you need to execute a VI that does pretty much the same as the "Read Channel Group" example, which is looping over the internal hierarchy of file->channelgroups->channels in the file and collecting the information you want in a table or database.
(2,469 Views)
