Save array in Matlab Level 5 format
I was wondering if there is any package which saves LabView arrays into Matlab Level 5 format. "savml" saves the data in Level 4 format.
Thanks!
(3,036 Views)
Hi DBM,
I think you are referring to the example program found here. This code is open source, and so you can modify it as you need to. I cannot find a premade example designed for Matlab Level 5 format. However, if you know the format, you can always change this code to work on Level 5 format.
Jeremy L.
Jeremy L.
(3,036 Views)
Thanks, Jeremy!
Yes, that example is Level 4 matfile. I'm going under the assumption that there is nothing out there for Level 5 and writing my own.
(3,036 Views)
