Making an array in a loop
If you see my complete VI you will see why I need 2 loops. Each loop gets different data. The VI I posted before with 2 while loops in a  flat sequence structure is just a representation of what I'm trying to achieve. Also your VI with a case structure does not work because all Data is valid and must be recorded.
Message 11 of 15
(2,167 Views)
@bajajvishal11 wrote:
If you see my complete VI you will see why I need 2 loops. .
OK, your attached PND is a snippet but your images in the post are not. If you attach code, attach the VI. If you want to show a snippet, embed it in the posts. You need two loops if two things need to run in parallel, but yours are sequential.
This is not sufficient to explain the situation. Where does the data come from? Data is typically different, so that's normal.
You still need only one toplevel loop and a proper state machine architecture. Your two loops have almost identical code! Why would a case structure prevent data from being valid or recorded? That argument makes absolutely no sense.
Message 12 of 15
(2,146 Views)
Hey,
 thanks a lot for proposing to have a look at my complete VI. I was just scared people would call me out for putting a big VI up there. Happens in other tech forums where people just want you to ask your very specific question and leave
Your VI is not very big in terms of code logic, just the front panel and diagram is unbelievably large for what it does. Why do the front panel objects need to be scattered across twenty HD screens. Why is the code such a sequence worm? I cannot really look at it on my laptop, so this need to wait until I can use a bigger monitor.
From a quick glance, this needs to be rearchitected from scratch. Glaring mistakes are:
  1. Overuse of sequence structures. Pyramids of while loops.
  2. disconnected controls that are used exclusively for data storage via local variables.
  3. Greedy loops that bur CPU doing nothing except polling a stop button. (see last frame)
  4. What's the difference between "array" and "output array". "array" is empty and you never write to it, so why is it even there? "output array" is derived from an empty array and one scalar and never contains more than one element. What's the point?
Message 13 of 15
(2,137 Views)
Accepted by topic author bajajvishal11
with initial position (2,2) which then increments in steps of 0.001
the distance at which the angle changes( rather shifts from motor X to Y ) increases by 0.002mm. Something like this:
Here's one possibility to create your spiral. I am sure it can be simplified further (one loop, no sequence, no local variables. unified code). You should be easily able to adapt it to your problem and increment your stepper motors depending on the changed complex component (RE or IM). (The history trace is just for illustration. You don't really need it)
Message 14 of 15
(2,131 Views)
Hey Thanks a lot for that. I didn't know I could use complex number in this way in LabView. Your solution was elegant and I was able to integrate it as it is with just 2 changes in my code. It was great learning. Thanks for that.
Message 15 of 15
(2,091 Views)
