Making an event structure run after alloted time?
I'm kind of new to Labview and use it for fun and other implementations but i have gotten stuck.
In following VI is supposed to act as a code lock, type in the right code and it's oppened and locks again after you press a button. But a function i would like to have is that the lock is locked again after 10s if no buttons where pressed after the lock was unlocked. "sorry if the text is confusing"
version in: LabView 2019
All help is appreciated and thanked before hand.
Best Regards Knight of Waffles
(2,555 Views)
Accepted by Knight_of_Waffles
Have you considered executing your code in timeout event case? You can wire 10000 to your timeout terminal of event case and place your code in timeout case so that it will execute   every 10s.
hope it was helpful
Thanks & Regards,
Bharath Kumar
GCentral
(2,513 Views)
Thanks missed that idea 🙂
(2,493 Views)
