Malleable VI Q
Why is case 0 declined?
Why is case 2 accepted?
(1,906 Views)
Accepted by topic author paul_cardinale
Case Selector is not wired.
(1,896 Views)
Thank you (D'oh!),
But now, why is case 1 declined?
(1,858 Views)
You have a wire connected to no endpoints in the frame.  You need to expand your block diagram window down to see it.
I will note that the way I found these was to remove the Type Specialization Structure and then see how the VI was broken.  I could then revert the VI once I figured out the issue and then fix it.
(1,851 Views)
Here's what I ended up with.
(1,804 Views)
