Manipulation of Array Data
I'm assuming the "0" I currently see wired to the call library function node is equivalent to the "method"?
Message 11 of 15
(1,872 Views)
for sure !
try with number 2...
Message Edité par tinnitus le 01-19-2009 01:41 PM
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 12 of 15
(1,870 Views)
2 should do it for you. I guess the other options were added with a new release of LabVIEW in either 8.5 or 8.6.
Chris Van Horn
Applications Engineer
Message 13 of 15
(1,862 Views)
Thanks Smiley Happy
Mhm, in my version there isn't even any explanation of what that input is.
Message 14 of 15
(1,859 Views)
Accepted by MerRhosyn
Hello Merhosyn,
does it work ?
if so , it would be nice to click on green button...  yellow is pretty cool too  ...:smileywink:
Tinnitus
Message 15 of 15
(1,812 Views)
