Masking Help needed
Hi
I have checked the example  mask.vi provided by labview. As we  know create mask has 4 inputs
image data
mask color
1-bit mask data
combine masks
I have an image which I can connect to image data. And If I want to mask circle out of rectangle then where should I connect this circle data???
 I
(2,816 Views)
Accepted by arrowminds
Hi arrowminds,
i think for a circle in your image you can use the "Draw Unflatten Pixmap". There you can connect an array of mask information.
Hope it helps.
Mike
(2,800 Views)
