Mass Compile has caused load issues
Software used: LabVIEW 2014 SP1 64-bit 14.0.1f3
OS: Windows 7 Professional
I thought it would be a clever idea to do a mass compile yesterday.  I selected the root drive, kicked it off and then walked away.
When I returned the computer had reset itself which seemed a bit odd.
Anyway, now when I open up the LabVIEW project, and open the top level VI, it cannot find <vi.lib>:Utility\miscctls.llb\LVBoundsTypeDef.ctl.
I traverse to the above directory, and can see miscctls.llb is there (and the date of the file has changed to approximately when I ran the mass compile), but when I select it I get the following error:
"An error occurred while listing the contents of C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\Utility\miscctls.llb"
So, I went to Control Panel --> Programs and Features --> National Instruments Software, and repaired LabVIEW 2014 SP1 64-bit.
After rebooting the PC, I still see th same issue. 😞
Is there a way to fix this short of doing a complete re-install?
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
Automated Production Test Specialty Premier Partner
https://wiredinsoftware.com.au
(3,576 Views)
I think you just need to do a reinstall.
I don't know why you'd think it would be a good idea to do a mass compile on VI's in the LabVIEW directory.  They would already be compiled for the version of LabVIEW they were installed as a part of.
Save mass compile when you are updating your own files, or 3rd party libraries.
(3,570 Views)
Sorry, I meant I did a mass compile of the root directory of my LabVIEW project.
Not the C:\Program Files\National Instruments\LabVIEW 2014 directory
Christopher Farmer
(3,564 Views)
There is no logical reason why mass compiling your own project directory would have done anything to corrupt files within LabVIEW's vi.lib directory.
(3,532 Views)
