Mass flow measurment from a Loadcell
Hello!
I have a load cell that I'm currently using to measure weight, but I would like to get the mass flow under a same time I'm measuring the weight.
I have tried using shift registers to get the current weight value and the old and then subtract these to X1-X2, and I have done the same with the time to get dt.  Then I can divide these with each other. It is just that I'm not getting the right mass flow. I'm guessing that I have to calculate in the data acquisition rate from my daq and how fast the while loop runs.
I haven't got it to work, and don't know what i should divide my signal with or if I should slow down the loop.
I know this task should be easy but I'm stuck and need a little help. Also I didn't find any examples for this task on the forum.
I'm attaching the my .VI if you would take a look at it.
Best regards Marulind
(3,158 Views)
Hi Marulind,
Are you still expreincing this issue?
Regards
Art
(3,053 Views)
Accepted by topic author maurlind
Hi!
I manage to solve it with some shift registers!
Best regards Maurlind!
(3,039 Views)
