change graph text spacing to division markers
How do you go about changing the text spacing to the division markers on y-axis on a graph.  In the attached image, the numbers cover up the graphical ticks on the y-axis.
hiNi.
(2,809 Views)
Accepted by topic author hiNI
You can try right clicking and doing an edit on the control.  It will show the individual parts that make up the graph and you can adjust.
To me it looks like those numbers are left justified rather than right justified.  I don't know what is normal, and if that is a property you can edit.
(2,804 Views)
