Master Spreadsheet for specific file format
Unfortunately, the naming convention will not be same. If you check all the attached CSV files, you will see that the naming convention will differ every time I put different sets of the file in the VI. This is indeed one challenge.
BTW, do you think you can help me with another VI?
Message 11 of 13
(510 Views)
Hey Huqs,
If the other VI that you are having issues with is part of this functionality I can take a quick look at it, otherwise I would say making a new forum post is the best option. It is best if each thread stays on topic to help others in the future who may be searching for answers to problems already encountered!
Hunter D.
Message 12 of 13
(501 Views)
Hello hdellere,
As you suggested, here I made the forum for my VI. If you have any suggestion, confusion please post them in the new forum. Thank you for all your help.
https://forums.ni.com/t5/LabVIEW/Filtering-file-from-Spreadsheet-based-on-parameters-listed/td-p/367...
Message 13 of 13
(496 Views)
