MatLab Script Node Fail
Hi everyone,
I am trying to use the MatLab Script Node in LabView 2024 and it shows the following error message:
Does anyone know what happened? Thanks for your time!
(1,247 Views)
Does the same issue happens when you tried to run the shipping example that uses the Matlab script node? And also does your PC has Matlab version 5 and above installed?
(1,211 Views)
Yes, the same issue shows up and I have the newest MATLAB installed.
(1,198 Views)
