Unable to transfer data using DMA FIFO from Target to host
I am trying to sample data and transfer it from the FPGA Target to host (cRIO-9022) using DMA FIFO. However, I think that this transfer is not working in my case. I will really appreciate if anyone can have a look at my code and point out the mistakes. I have used this code earlier on different cRIO and computer and it was working fine. However, with different cRIO ( but same model no) it is not working. I am using cRIO-9022 with FPGA chassis 9114.
Thank you!
Kind Regards,
Okidoki
(876 Views)
No code was attached. Please attach your code and the entire project.
https://tmesystems.net/
(866 Views)
(863 Views)
It will be great if anyone can help me with this. I am still facing this issue.
Kind Regards.
(812 Views)
