Match Pattren Problem
i am using Match pattern String Function in Labview to Search the String. the Problem i am getting is Say i have strings in the order
ABC
Test1
Test
If i give Test has Regular Expression to Match, i am getting Matched Output for Test1 , i mean Before Substring is  ABC, Match Substring is Test and After Substring is 1 Test.  i am lookinh for the 3rd line. i dont have any commas or dot in the end of the string. Please help
(3,718 Views)
I would probably use Match Regular expression in this case.  Use the regex 'Test\b' which matches the string 'Test' followed by a word boundary (space, end of line, end of string, etc.).
(3,690 Views)
Accepted by KiranKeshavegowda
Well you could have the search look for "Test\n" or "Test\r\n" depending on your format.  Then you'll match on a string that has a line that ends in "Test".  Of course this would only work if Test is not the last line in the file.
But yeah regular expression would probably be easier.
(3,651 Views)
Hello All,
thanks for the Help.
Kiran
(3,546 Views)
