Match Regular Expression Format
Hi Everybody,
I'm communicating with a scale, using the Continuous Serial Write and Read sub-vi.
It outputs a string with a format:
ST, GS, + 0.00 g
I want to extract only the number and convert it into a double so I can graph the weight change over time.
The expressions I've been using with Match Regular Expression, have not been working.
I've tried
[0-9]+(\.[0-9]+)*
and
d+(\.\d{2})?
Is there a better way to parcel this data?
(4,653 Views)
@smat123 wrote:
Hi Everybody,
ST, GS, + 0.00 g
I'm a big fan of Scan From String and Format Into String.  I gather that this is the output from a Balance.  Are the first two fields always 2 characters long?  That is, is the format of all of the strings <2 char>, <2 char>, <number> <unit>?
If so, I would pass the string into a "Scan from String" with format %2s, %2s, %f, %s.  If I don't need the first two fields, I can just not wire those outputs.  The third output will be the number, and the fourth will be the unit ("g") in your example, but if your balance autoscales, it might become "mg" or "kg").
You can also do some of this with Regular Expressions.  If you do, take advantage of the comma separators to skip past the first two fields.
(4,646 Views)
Accepted by smat123
Hi smat,
it reminds me on the scales we use…
Try this:
(4,643 Views)
Damn, you others are too fast, but I'll post what I made all the same:
This reads the sign automatically and outputs the DBL as positive or negative.
Cheers
(4,634 Views)
