Match regular expression only gets double digit number between brackets
I am using match regular expression with the following expression. It is only able to get any numbers that are not single digits. I want to grab any values that are between >< in the string and create an array.
So
<ENV_SCALE>182</ENV_SCALE>
<TXFE_GAIN>2</TXFE_GAIN>
would output
182
2
Any help would be appreciated. I've attached what I have so far. Right now I still have the >< and it can only grab numbers that are not single digits.
(3,950 Views)
Accepted by topic author syedzeeshan
Use  (>.[^(<>)]*)<    * instead of +
(3,931 Views)
Since it is solved, its fine. But please try to have the question in a single thread
(3,907 Views)
