Match two columns in a txt file randomly
Hi Guys!
I have an input txt file like this (the columns are separated with tabs):
A:    B:
Kyle    Josh
Anna    Martin
Jon    Jenny
I need a VI which randomly matches pairs, one item from "A" with one item from "B". It should match all the pairs (in the example 3 pairs), and one item can be used only once. Of course I don't need the first line to be matched (the letters "A" and "B"). The number of the lines can change, and the values are not fixed.
I would like to kindly ask for your help.
(2,983 Views)
Hi hofferistvan,
- read the file using ReadFromSpreadsheetFile into an 2D array of strings.
- Delete the first row, index the first two columns.
- Feed both columns as 1D array to shift registers of a FOR loop.
- Delete a random element from both 1D arrays in the loop and output them as pair.
- Repeat the loop as long as there are elements in the array…
(2,966 Views)
Thank you, but could you tell me, which functions I should use at each step you listed?
It would be a great help.
(2,953 Views)
Accepted by topic author hofferistvan
One other approach:
Read file and delete header as GerdW suggested then use the below
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,936 Views)
Thank you, it seems to work. But one question: how is that function called on which there is "DBL abc"?
(2,926 Views)
UnbundleCluster
(2,917 Views)
